keypad entry system
Old Dec 7, 2014 | 07:17 PM
foxy510's Avatar
keypad entry system
couple mths back my kes stopped working wont light up , wont respond to factory code... pulled connection in door apart with volt tester lite came on on tester for 5 seconds then went off tried numerous times with same result im thinking key pad has met its demise. any suggestions?
Old Dec 7, 2014 | 11:43 PM
JackandJanet's Avatar
Sounds reasonable, but I'd check the wiring to the keypad too. Use a multimeter, not a test light. You probably also need a wiring diagram, which I don't have. If any of the wiring to the keypad is faulty due to a poor connection or a broken wire, it would probably give you the symptoms you describe.
- Jack
