Which power inverter for corded drill? (If possible)
Old 11-29-2014, 06:40 PM
Red_98_5_Speed's Avatar
Hello all, I was wondering if I could use a power inverter that I could plug into a cigarette outlet to use a corded drill( 10 amps and a max wattage of 980) and if it would even be possible. Thanks!
Old 11-29-2014, 08:46 PM
anything over 200w is going to have to have dedicated battery cables
Old 11-29-2014, 10:16 PM
So would I be able to connect the inverter to the car battery that is already on there and have it work or would I have to have a whole other battery?
Old 11-30-2014, 07:43 AM
MGDfan's Avatar
You can use yer current battery. Just ensure that you keep it charged - that's a significant load.
BTW - don't see this being audio-related - perhaps ask a Mod to move yer thread to Electrical?
(If Patrick keeps shirking his housekeeping chores, this place is gonna start resembling the trainwreck that is F150forum.com )
BSB
Old 12-01-2014, 03:41 PM
tcp2's Avatar
Current rating
That 10 amps is at 120V AC. To get that out of your battery you are drawing approximately 10 times that much current...100amps at 12V plus inverter losses. Those current requirements mean 4 gauge welding wire at a minimum. Electric motors are inductive which means the input current when you first start drilling can be quite a bit higher as well.
Quick Reply: Which power inverter for corded drill? (If possible)
