How to Disable lights with door OPEN
Old Aug 23, 2014 | 12:38 AM
texasmark's Avatar
Hi all brand new member here,
I searched the site and tried the tricks people gave to disable the lights that come on when the door is opened (2014 F150 reg cab XL). I tried the info/reset buttons on steering wheel, no adjustment; tried the dimmer button by tapping all the way up and all the way down, no help; all that did was keep the bed light on longer, no good. This year does not have the round dial to turn them off like some of the older models.
I want to disable every light that comes on when the door is open (dome light, running lights, bed light). I don't care if I never see these lights ever again when the door is open. I will gladly pull a fuse, pull a relay, or go in and bypass the switches if anyone has detailed instruction on how to proceed. I do not want to fiddle with the door lock mechanism every time the door opens to solve this, I want a permanent solution, please.
I also could loose the door chime and the seat belt chime if anyone has an answer for these too.
This is a very basic truck (hand crank windows, no key fob, etc).
Thank you everyone. TX mark
Old Aug 23, 2014 | 05:54 PM
texasmark's Avatar
I figured it out (interior and bed light), it is fuse 12 in the passenger compartment. Running lights still come on however.
