Temperature gauge suddenly reading low.
My temperature gauge (IIRC) has always read about 200. The last couple months
(I only drive my truck every so often) the aftermarket gauge (http://iequus.com/Product/8162/1-1_2...perature-Gauge) now reads 160-170. The day temps are only in the 70's but shouldn't the thermostat (new-195 deg) bring it up to above 180? I drove the it today for awhile with the AC on full and it only got to 170. I have checked the connections both power and at all points, removed and cleaned the temperature sending unit. Should I buy a new temperature sending unit or is it most likely a bad gauge. As near as I can tell the factory gauge reads about what it always does. Anyone know what the resistance value of the temperature sending unit should be cold/hot ? Any other ideas? Shouldn't the top hose get too hot to hold? It doesn't.
