door lock problem please help
Old Jun 5, 2014 | 06:14 PM
Mustangt69's Avatar
Did have a water issue in drivers pillar from sunroof drain unplugging and water dripping off grab handle
Old Jun 10, 2014 | 09:17 AM
Mustangt69's Avatar
Here is an update for everyone. found out the door locks should work without the rap module installed. my rap module started clicking again, think it was trying to pull power through the module to operate the locks. Searched further and found a pretty crusty ground wire bolted behind the drivers kick panel by the emergency brake right along the floor panel. cleaned that up but still no fix. looked at the plugs mounted along the kick panel and noticed a black wire corroded. I believe its the middle grey plug. i disconnected the plug and the wire fell out of the connector. fiixed the connection and my door locks now work like new. I was also able to reprogram my fobs after fixing this wire. hope this helps someone. i had the leaky windshield/sunroof drain so this could be a "problem wire"
Old Jun 10, 2014 | 12:02 PM
ishootstuff's Avatar
Nice work!
