Door Ajar light on - WD-40 Does NOT work.
Old Feb 15, 2014 | 04:54 PM
orlando75's Avatar
Door Ajar light on - WD-40 Does NOT work - Door lock button doesn't work either.
Any suggestions on what else to try for a door ajar light on that's very annoying? I tried the WD-40 and that didn't work. Sprayed almost an entire can. In addition, the door locks will not work. I have to use the key fob. Pressing on the door lock button on the doors has no effect. I have a 2006 regular cab so it has the half doors on it. Sprayed them all. Any ideas? Thanks in advance for any help!
Old Feb 16, 2014 | 08:34 AM
projectSHO89's Avatar
Pull the latches out and replace the switches.
Pull the lock actuators out and either repair or replace them.
Old Feb 16, 2014 | 08:58 AM
MGDfan's Avatar
Good mornin';
OP - you stated that yer door lock actuators will work via the remote ( key fob )? (If you meant using the key itself, just ignore me )
Then it may simply be a case of dirty contacts in the door lock switches.
These two how-to's, while not specific to the lock switches, do show the general R&R procedure and contacts - in Jack's article he mentions burnishing those contacts.
Worth a try - before spending $$$ on new switches.
https://www.f150online.com/forums/ar...-switches.html
https://www.f150online.com/forums/ar...ow-switch.html
And here's a couple related door articles ( just fyi):
https://www.f150online.com/forums/ar...uator-diy.html
https://www.f150online.com/forums/ar...door-wire.html
good luck!
MGD
Old Feb 16, 2014 | 04:09 PM
orlando75's Avatar
Thanks for the input. I might have to take it to a mechanic. That might be a bit above my pay grade, perhaps.
