Switched power source 2013 F150
Old Jan 17, 2014 | 10:13 AM
rpkiwi's Avatar
Hoping someone can help as we have just purchased a 2013 F150 crew cab at work and would like a switched power source as we need to install communication radios as well as a strobe light.
Was told by ford that we would have to go direct to battery,is that correct?
The strobe is fine of the battery,but the guys have a tendency to leave radios on with flat batteries resulting.
This topic has probably been beat to death,but I do appreciate the help.
Thanks Roger
Old Jan 17, 2014 | 10:31 AM
MGDfan's Avatar
Thanks Roger
Hi.
try this: https://www.f150online.com/forums/4334852-post14.html
May be slightly different for a '13 fuse number-wise so you may need to probe around a bit with a DVM or test light.
Use that feed to trigger an appropriatley-sized ISO relay (30-40A) to actually supply your equipment. And yes - primary power to the relay for the loads needs to come from the battery fused right AT the battery.
MGD
Old Jan 19, 2014 | 06:39 PM
rpkiwi's Avatar
MGD thanks for the info will be looking into this,this week.
Roger
Old Jan 19, 2014 | 07:47 PM
MGDfan's Avatar
Roger
Roger that, Roger
If yer looking to power several devices, you may want to use something like one of these
to give each a separate switched (or non-switched) fused supply...
http://www.bluesea.com/products/cate...locks/ST_Blade
http://assets.bluesea.com/images/pro...26_install.jpg
http://www.centechwire.com/Auxiliary...Panel-AP-1.htm
http://www.fuzeblocks.com/
Good luck, and please let us know.
MGD
