Clearance Lights
Old Aug 29, 2001 | 12:31 AM
Cheesefood's Avatar
Clearance Lights
How can I get the roof mounted lights if my F150 does not have them?
Old Aug 29, 2001 | 08:25 PM
XceLenT Driver's Avatar
Cheesefood,
Not to sound like a smart a$$ but there are two ways that I know of:
1) Install them yourself, or 2) pay someone to do it for you.
It's not a easy job since and will require lots of drilling and wire "snaking".
Probably cost prohibitive if you can't do it yourself.
Old Aug 29, 2001 | 09:45 PM
bigblackford's Avatar
Cool
Installing clearance lights really isn't that bad. And the headliner will pull down a little bit in the front after you take off the plastic bracket where the sun visors "park". I installed a set that I got from K-Mart on the black '97 that I use to have. This time I'm looking at getting the ones they put on the SuperDuty's from the dealer and putting them on. They cost about $7/ea. I just made sure to put primer on the metal after I drilled the holes and used silicone on the plastic part that touches the paint so they wouldn't leak. Hope this helps.
