Cruise turns off with Turn signal.
Old Jun 24, 2013 | 02:19 AM
thenewbreed's Avatar
So every time I have cruise control on and I turn my left turn signal on the cruise turns off. It only does it with the left side. I have LED brakes lights but have added capacitors so I don't have the quick blinking issue. My reverse lights aren't out either. I have normal turn signal bulbs up front which are working correctly. The after market auto start stopped working also. The only other thing I can think of is the auto start module has failed. But I don't know how to check that. Any ideas?
Old Jun 24, 2013 | 03:44 PM
SSCULLY's Avatar
That sounds like the left tail lamp is showing out to the system.
Another member posted back about some rear relay, asked for clarification never got any ( EVTM does not show a rear relay ).
Did you install capacitors or load resistors ?
- Should be load resistors.
Might want to check that the load resistors are still in place.
I had the same symptoms happen on my '06 Lariat, on a trip from Chicago to DesMoines IA, it was the left stop / turn that was blown.
Also, Autostart or remote start added ?
Old Jun 24, 2013 | 03:56 PM
You're right they are resistors. The lights work fine though. I'll double check.
Yes the remote start was added three years ago with the aftermarket alarm system.
