Clicking on brake controller
Old Apr 12, 2013 | 07:01 PM
ijr1508's Avatar
I have this old Valley brake controller on my truck that makes a random clicking noise (at random times even when the vehicle is off).
Using a voltmeter, the power showed 12V, and the brake pedal feed showed 12V. But the Bl wire to brakes gave 5 to 6 volts constant. The manual level the same. It seems to send 1.8V to the brakes without brakes applied. The led doesn't seem to light up either.
Should I just throw this thing away and get another?
Here's a pic:
Old May 6, 2013 | 08:29 PM
pino_jonathan's Avatar
In short, the answer is yes.
However, before you do, be sure that your red wire(brake switch feed) is tied into the correct wire on brake switch harness.
Old May 8, 2013 | 09:59 AM
ijr1508's Avatar
yeah. I think I know what happened. I bought the truck, and I wanted to get the reeking smoke smell out of it. I borrowed a ozone blaster from a friend and ran it in the truck. I wasn't told till afterward that ozone damages electronics. (because it worked before). So, for anyone planning use this don't brake all your electronics.
