04 f150 stx headlight switch removal
Old Mar 17, 2013 | 10:23 AM
roempty's Avatar
I would like to remove switch and dash . I have looked for pics,or instructions for and 04 with no luck. Anyones help would be great . Thanks in advance
Old Mar 17, 2013 | 03:00 PM
SSCULLY's Avatar
removing the switch, you can remove the side panel ( towards the a pillar / door ) and reach in and pop out the switch tabs from that side.
Removing the dash, not too sure how far you want to go.
Thread in the how to section on removing the cluster.
https://www.f150online.com/forums/ar...y-install.html
The complete dash, the silver part is one piece over the entire dash, so that is quite a bit of removal, that you would just need to dive into once you have the cluster and center surround out ( and the airbag above the glove compartment ? )
