wiring light bar
wiring light bar
i ordered a light bar for the back of my truck and want to harwire it into the 7 pin. I made a list of the wires and the colors, so I need your help if the colors and the function are the same.
white-ground
orange-power/12v
yellow-left signal
green-right signal
brown-running
grey w/ brown stripe
blue- electric trailer brake which wont be used for the light bar
white-ground
orange-power/12v
yellow-left signal
green-right signal
brown-running
How are you going to turn it on if its wired into that? Just leave it running full time? Also what lights are you going to be using? Because I don't think the wiring in the trailer hookup is big enough.
You'd be better off just running a new power wire from the battery to a relay for them imo.
I think pizzaman711 is think of light bar, as in Whelen, not light bar as in line of fire.
You can get right behind the 7 pin, and splice there, that is where I got mine at. I inline solder Tap a 4 pin trailer tow adapter on mine. The other one I did, same thing, but added a 2 pin SAE connector for the reverse lamp circuit.
This way if I ever need to remove it for some reason, I can do it quickly vs cutting the wires. That is just me, I have seen others go direct to it.
Seem to missing some wires in that list :
I did not see the reverse lamp circuit, and I don't know if you are calling power/12v the Trailer Tow battery charge circuit.
The color in that diagram is just to point out the different functions.
Just look at the back of the 7 pin trailer tow adapter, the wiring will line up as the standard 7 pin RV plug.
