CB install questions
Old Jan 31, 2013 | 01:39 PM
LouisianaBoy's Avatar
Ok here is my thing...I have the overhead rail system in my screw. I dont use the compartment for anything at all. I recently ordered a cb radio and the size is perfect. My plan is to pull off the compartment and remove the swing down door off the compartment. I will install cb in that area. I have three wires there which are in a hole in the headliner. I assume its for the dvd player that goes there. I will tap in that for power. I will run my antenna line through that hole to my third brake light. My question is....how easy would it be to pull from that hole to the third brake light hole? cant be that hard? I havent taken off the third brake to look but I assume there is pretty much a straight shot above the headliner to the brake light. If anyone has done this...was it a fairly simple task?
Old Jan 31, 2013 | 03:43 PM
camopaint0707's Avatar
shouldn't be that bad if you remove the headliner
Old Jan 31, 2013 | 04:25 PM
Im not going to remove the headliner...way too much trouble. Im pretty sure I can straighten out a clothes hanger and stick it in from the brake light and pull it back through...if I have to remove the headliner Ill just install in the the big black hole known as the center shifter console lol.
