1991 f150 xl
Old Jan 12, 2013 | 05:00 PM
owens13f's Avatar
Angry 1991 f150 xl
So It appears that i have a problem with my Turn Signal Flashers or something.
I have check Fuzes/Relays Installed a new Turn Signal Switch, but have failed to fix the problem so far.
I almost certain it has something to do with this wire/plug right underneath/attached to the area that you hook up the comp to for testing check engine lights.
Reason being is when flicking the Turn Signal Switch I heard a click in that area.
Upon further investigation i found a wire/wires with a white plug with a few prongs in it attached to the check engine light test port.
I can put my finger in it and flick the Turn Signal to the on position and feel the click. There is nothing plugged into it, and no other loose wires that i can find.
Could really use some help here guys.
Old Jan 18, 2013 | 12:52 PM
owens13f's Avatar
typo my bad its a '99
