Curious about a fuse
Old Aug 27, 2012 | 03:50 AM
TheSauce05's Avatar
Can anyone tell me what fuse location 12 "Rear Auxiliary Power Point" is for on a 2000 F150 4.6 Supercab in the engine compartment fuse box? There's no fuse in there. Wondering if it was an option for the truck or if its just a spot that's there for another vehicle (using the same distribution box for multiple vehicles). If its an option for this truck I wouldn't mind figuring out how to add it to mine. Another 12v source would be nice. Thanks!
Old Aug 27, 2012 | 07:58 AM
SSCULLY's Avatar
Cannot recall if the '00 SCab had the rear power point. Did you check both C pillars ( by the seat belt ) for a DC power outlet ?
I know the '01 SuperCrew had one back there ( passenger side if I recall correctly )
The fuse panel was only a single version, used for all trim levels and equipment trucks. The wiring to a given slot is not installed, if it is not on the truck you have.
Old Aug 27, 2012 | 11:32 AM
TheSauce05's Avatar
I'm pretty sure there's not a power point back there. I'll have to look at the fuse box again and see if the pins are there or not.
Old Aug 27, 2012 | 04:14 PM
TheSauce05's Avatar
Well, no wiring to that fuse, so I guess it's just for anther vehicle. Got another question, though. Was fixing the intermittent odometer today and found a plug that goes nowhere behind the light switch. Thought it was for fog lights, but I don't have fog lights and, from what I can tell, I don't have the wiring for fog lights. I have the fuse in the cab box, but no fuse and no wiring for the fuse in the engine compartment. Also, no plugs under the front of the truck for the lights. Anyway, here are a couple of pictures of the plug in question.
Old Aug 28, 2012 | 02:52 PM
TheSauce05's Avatar
Ok, from what I can tell from the manual in the sticky it appears to be WPT-181 which has 4 possibilities. They are adjustable pedals, moon roof/sun roof, reverse park aid, and seat lumbar. Any idea on which it is in this truck?
Old Aug 28, 2012 | 03:38 PM
F150 never had reverse parking aid in the 97-03, only the 00-02 Expy
Old Aug 28, 2012 | 03:56 PM
If that was behind the light switch it could've been for the adjustable pedals or possibly fogs....
Moon roof controls were on the over head counsel....
Old Aug 28, 2012 | 04:44 PM
TheSauce05's Avatar
I think it was for something on an expedition. Most likely reverse parking aid, if I were to guess. Same wiring for multiple vehicles again. Wonder if it could be tapped into to use for something else...
Old Aug 29, 2012 | 08:27 AM
SSCULLY's Avatar
Keep in mind the pigtail catalog gives the typical usage of the connectors, it is not a full listing of what a given connector is for.
It would be for the power pedal switch. The connector that the fog lamp switch wiring is on should already be plugged in ( inline connector ).
Not all trucks have the complete wiring in them, but if you have the pwoer pedal connector, you might want to take a closer look for the fog lamps ( if you want to install them ). The ends would be tapped against the headlamp wiring harness up high.
Old Sep 3, 2012 | 03:49 AM
TheSauce05's Avatar
Double checked for the fog wires under the front. Still couldn't find them. Also, it doesn't look like there are any terminals in the engine bay fuse box where the fog lamp fuse should go. Is there a pinout diagram for the fog lamp switch? If I could wire in after market fogs to a factory switch that would be awesome.
Old Sep 3, 2012 | 05:23 PM
SSCULLY's Avatar
This shows the modification for the fog lamp mod ( modify the plastic ramp so they will pull out in the park position ), ignore the red line and text.
If you found BJB ( aka Battery Junction Box, engine compartment fuse panel ) fuse #9 to be empty on both sides, then you confirmed that you do not have the wiring.
As you are thinking, it is easy enough to wire the fog lamp circuit from the factory switch to an external relay ( the yellow wire ).
Old Sep 4, 2012 | 07:31 AM
TheSauce05's Avatar
I'm not sure what you're referencing here with this schematic. I've heard of the fog lamp switch mod, but I thought that was just for using the fog lamps in the parking light position as well as the low beam position. Not really interested in doing that, just wondering how I would wire a factory switch (when/if I get one) to a set of fog lights. Right now, I just have the standard, bottom-of-the-line switch with off, parking lights, and low beams. No auto lights or fogs. In fact, my switch doesn't even come out like most (pull off the ****, turn it, put it back on, turn it and out it pops). Mine actually has to be pried out. It is held in with little metal tabs that are just clipped on the sides of the switch. Anyway, I'm just curious for a possible future add-on. I'd rather not use the crappy little toggle switch they provide in those fog lamp kits. So I guess what I'm really asking is, which pins on the back of the light switch that control fog lights do what so I know where to send the wires. I figure I'll route the wires through the firewall, into the dash, and into the switch, not unlike a regular fog light install, but instead of using the switch they provide I'd like to just use the Ford switch. BTW, thanks for your help and patience.
Old Sep 4, 2012 | 07:35 AM
TheSauce05's Avatar
Wait, I see what's going on in that schematic. Ugh... I had to look at it a little closer. Unfortunately, it doesn't really help because since I don't have the wiring for the fogs, the color coding doesn't help. Once I get the switch, all I'll have to go by is the pins on the back of it and I'll have to use my own wiring, which will basically be 2 wires and the switch will just cut the power in and out. I may or may not go with a relay. I guess that would depend on whether it's recommended or not (I'm guessing it probably is).
Also, I apologize if I'm getting confusing. Just got off work and I'm dead tired.
Old Sep 4, 2012 | 10:00 PM
SSCULLY's Avatar
For the cost, go with a Carling Tech switch, you will be money ahead and be able to install it for what ever you want ( fogs on with park or low beam only ) and save about 60.00 in the process.
You will need a relay regardless of which switch you go with. You might get away with some of the LED aux lamps on a 20A carling Tech switch, but you really go with the relay anyway.
I have self contained Trail tech HID lamps on my ZG-1000, the switch is rated for the amp draw of the ballast. If I try to run them direct, the ballast will not ignite ( current in rush ), if I install a 10 A relay they work fine all day long.
- AMP draw of the lamps compared to the switch is not everything.
