lightning wont start
Old Aug 8, 2012 | 11:52 PM
SA-10's Avatar
hey i have a 2000 lightning just fired the engine a couple days ago after rebuilding it, today i started it and it cut off it crank no start ,the odometer is not reading and it sounds like the relays are clicking under the hood relay 301 you can feel it clicking any of you guys had this problem?
Old Aug 9, 2012 | 12:29 AM
JackandJanet's Avatar
SA-10, I moved your question to the Electrical forum, because I suspect your problem might be best answered here.
Welcome to the forum! (And I hope your problem gets solved soon.)
- Jack
Old Aug 9, 2012 | 07:12 AM
projectSHO89's Avatar
Check the integrity of all your ground straps and cables that were disconnected when the engine was removed. One of them is probably bad. If those check out okay, then check the battery circuit feeds into the underhood fuse/relay panel, and the fuses and relay that are critical for powering the PCM.
Old Aug 9, 2012 | 10:36 AM
SA-10's Avatar
Ok I will try that. Thank you for the help
Old Aug 9, 2012 | 09:43 PM
SA-10's Avatar
Ok Got it started it was Fuse #18 that needed to be repalced. Now back to figuing out why some cylinders aren't firing. I may have blown the fuse while checking power at the injectors
