12v to 110 converter?
Old Jun 30, 2012 | 06:10 PM
DSGSTX81's Avatar
After Googling threads from here for an hour, and searching manually for another 1/2 hour, I just decided to ask lol.
Me n the fiance just bought a Simmons Queen air mattress for the truck bed when we go camping. It came with a 110v connected pump that does the job in about 2 minutes. My '08 has the Flow Through console, but no 110v outlet like the new trucks--since buying a new '12 or '13 model is outta budget, would it be ok to plug a 100w Stanley 12v to 110v converter into my rear power point? Here is a link to the product...
http://www.walmart.com/ip/Stanley-10...erter/14560011
Like I said, it would only be used for that purpose, perhaps 6-10 times during the summer months, and the mattress can deflate without the pump. Just don't wanna blow a fuse or damage the PP or my battery whilst away from civilization. Thanks.
Heath
Old Jun 30, 2012 | 07:08 PM
projectSHO89's Avatar
need to know the power requirements of the inflation pump for an accurate answer. The inverter you indicated will only supply 100 watts
Old Jun 30, 2012 | 07:36 PM
DSGSTX81's Avatar
I'll try to find it and get back with y'all. Just a simple pump that came with the package, but I'll try to find a serial number.
Old Jun 30, 2012 | 08:44 PM
Richard D's Avatar
When I had my wakeboard boat for inflating the tubes we used this. Could be another option for you.
Amazon Amazon
Old Jun 30, 2012 | 10:05 PM
DSGSTX81's Avatar
Model: AR-101
Power Supply: 120v~, 60Hz
Current: 0.75A
Power: 90W
Listee: Smartrend
Manufacturer: HBY
So, if the 100W Stanley actually is 100W, and the Pump only draws 90, I should be good, correct? Like I said, it literally takes only 1 1/2-2 mins to fill the bed to capacity.
And, Richard. Thanks for the link, might go that route if all else fails...
Old Jun 30, 2012 | 11:49 PM
jgger's Avatar
OGTerror did an inverter in his truck, real clean job too. He loves to help out. Might PM him and see what he has to say about it.
Old Jul 1, 2012 | 12:09 AM
DSGSTX81's Avatar
Thanks, will do.
Old Jul 1, 2012 | 06:54 AM
The power requirements of the inflator indicates you're just barely within the capability to use that inverter. It's worth a try, but don't be surprised if it blows the inverter and you end up getting one with a higher current/power capability.
Old Jul 1, 2012 | 10:05 AM
DSGSTX81's Avatar
OGTerror sent me a link to a Bestek one on Amazon that should work just right.
Old Jul 14, 2012 | 04:44 PM
DSGSTX81's Avatar
Decided to go with the DieHard Gold 425w from Sears. I'll let you guys know how well it works once I get to test it.
Old Sep 12, 2012 | 10:58 AM
DSGSTX81's Avatar
Finally got around to buying the Sears DieHard Gold 425 watt inverter, and it works like a dream I even installed a hideaway for it inside my center console, pics forthcoming.
Best 50 bucks I ever spent.
