High beams, FTP, and dash indicator do not work.
I have a 2008 FX4 screw. My headlights work, my fogs work, and every other indicator on my dash works. When I go to turn my high beams or pull back on my FTP, the head lights go out and the fogs stay on. Also, the dash indicator for the high beams does not light up. I replaced the head lights, checked all connections to the bulbs and dash and checked my fuses (the ones associated with the dash and lighting). I'm not sure what happened or how to fix this.
Thanks!
Jake
Thanks!
Jake
Check fuses F35 and F40 in the CJB first.
If both fuses are good, additional troubleshooting would need to be done to see if you have an MFS fault, a wiring/connector problem or a faulty high beam relay which is located in the CJB.
