window with a mind of its own
Old May 6, 2012 | 09:29 PM
munchieman's Avatar
I have 98f150 super cab driver side power window works when it wants to i have replaced door control switch and motor check wire between door checked fuses . one day you start truck and its working perfectly no bines no slow downs.the next day it just wont work at all.very confused
Old May 7, 2012 | 12:18 AM
SSCULLY's Avatar
When it is not operational, do the lights on the truck dim ( similar to when the window is down, and you press the down button again ) ?
Is it always not working in the same direction ( up or down or both ) ?
If it is down, are you pressing the button far enough to activate the OTD feature, or are you only part pressing the button as in the down function ?
The days it is not working, has it rained ?
Old May 7, 2012 | 04:33 PM
munchieman's Avatar
to answer your question the window when it works it works perfectly .when it doesnt it wont work at all it very seldom stops working when its working until i go to start it the next day then it wont work or it will. i dont think it has nothing to do with dampness i do think when it is not working its electrical i have tried tests and there is power to the switch when it is not working there is no power coming to motor is there a relay or hidden something i am missing thank you for the come back.
Old May 7, 2012 | 04:40 PM
munchieman's Avatar
=munchieman;4834485]to answer your question the window when it works it works perfectly .when it doesnt it wont work at all it very seldom stops working when its working until i go to start it the next day then it wont work or it will. i dont think it has nothing to do with dampness i do think when it is not working its electrical i have tried tests and there is power to the switch when it is not working there is no power coming to motor is there a relay or hidden something i am missing thank you for the come back.[/QUOTE]
Old May 7, 2012 | 07:00 PM
SSCULLY's Avatar
Try it again....
Old Jul 4, 2012 | 06:09 PM
munchieman's Avatar
no i have come up with one solution i think it is the g.e.m.pack the wireing goes though it how do i get to it and is there a way too bypass this the moter will work with battery
