headlights
Old Feb 23, 2012 | 12:57 PM
Tonyjoe's Avatar
headlights
when i turn my lights off, the running lights stay on. I have already replaced the switch and its not fixed... what else can I do to find the solution?
Old Feb 23, 2012 | 01:40 PM
BL4CK3D0UT's Avatar
Do you have a multimeter? What year f150
Old Feb 24, 2012 | 08:38 AM
Tonyjoe's Avatar
I can get a multimeter, and its a 1997 f150
Old Feb 24, 2012 | 01:10 PM
BL4CK3D0UT's Avatar
When do the headlights turn off or are they always on? Have you done any recent mods or when did this started happening?
Old Feb 24, 2012 | 01:44 PM
Tonyjoe's Avatar
I got the truck like that... the guy failed to tell me. I can turn them on just fine. but to get them off i have to undo the battery. they dont stay on all the time. just when i turned the switch. and i dont know of any tests to do or anything.
Old Feb 24, 2012 | 02:05 PM
SSCULLY's Avatar
...<snip>..they dont stay on all the time. just when i turned the switch. and i dont know of any tests to do or anything.
So if you disconnect the battery and reconnect it, they are off until you turn the switch on ?
Is it when you turn the headlamps on, or it does the same thing when you turn the parking lamps on ?
Do you have DRLs on that truck ( if so, factory or aftermarket ).
Are there any modifications to the truck when you got it ?
BL4CK3D0UT's Avatar
Have you checked the DRL relay? Sounds like its bad
Old Feb 24, 2012 | 02:10 PM
Tonyjoe's Avatar
All I know is the guy had subs hooked up to it at one point. The radio is messed up to but I dont care about that. And is there anyway you can tell me where that DRL relay is?
Old Feb 24, 2012 | 02:44 PM
BL4CK3D0UT's Avatar
passenger side dash
Old Feb 24, 2012 | 02:52 PM
Tonyjoe's Avatar
Ok thanks alot
Old Feb 24, 2012 | 07:18 PM
SSCULLY's Avatar
How is the radio messed up ?
- Have you tried pulling the fuses for it ?
forgot to ask, does the truck have autolamps ?
