power mirrors
Old Jan 22, 2012 | 11:32 AM
ehileman's Avatar
power mirrors
2001 f150....power mirrors both stopped working...know which fuse controls them?
Old Jan 22, 2012 | 12:37 PM
SSCULLY's Avatar
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenan...ls/default.asp
Cab fuse panel #4 ( PDF version of the owners manual, page 132 )
Old Jan 22, 2012 | 08:40 PM
ehileman's Avatar
just bought this truck so...found fuse 4 was missing...installed fuse...driver side mirror pivots up and in and the passenger side mirror pivots up and out only....switch problem or mirror motor problem?
Old Jan 22, 2012 | 10:37 PM
SSCULLY's Avatar
I would say switch problem, as the switch only moves the mirrors the same direction ( in on one side is out on the other ).
Remove and test the switch prior to purchasing a new one.
Old Feb 5, 2012 | 08:03 AM
ehileman's Avatar
removed the switch and unplugged the harness then reconnected it and it worked...thanks scully
