Relay for Trailer?
Old Dec 9, 2011 | 08:55 AM
Jim Ciampi's Avatar
Relay for Trailer?
I have a new 2011 Ford F 150 and when it was delivered there is a relay in the glove box.I assume it is for the trailer but I can't find any info on where it goes in the fuse and relay box.I believe I need it in order to get a 12 volt hot wire in my seven pin trailer plug,but am not sure.Any help would be appreciated.I live in Virginia Beach and I bought the truck from my grand daughter in Michigan.In other words I never got a run down on the relay or anything else for that matter from a salesperson.The truck was delivered to my home....Thanks in advance
Old Dec 9, 2011 | 10:10 AM
SSCULLY's Avatar
I am taking a SWAG ( based upon my '01 - so take it with a gain of salt ), but I would say it is for the trailer tow adapter battery charge circuit.
Looks like relay slot #9 in the engine compartment fuse panel ?
double check you owners manual against what is installed in the truck.
The trailer tow adapter install directions might be stuffed in the owners manual case, it is a 8.5x11 page size, ~ 6 pages ??
I only have the PDF of my '01 and '06 directions, so that does you no good.
Old Dec 12, 2011 | 09:10 AM
Jim Ciampi's Avatar
Got ur done, the relay was in fact for the trailer plug.I installed the fuse and relay and now I have the lead in the seven prong plug energized. I can also pull a connection off the center lead for my reverse trigger wire.
Thanks for all your help.I hope I can help someone here on this forum in the future to pay it forward. Thanks again
Old Jan 7, 2012 | 08:04 PM
nu-supercrew's Avatar
Relay #5 is in the glove box. I thought I wired everything up wrong! Thanks!
