4x4 dash lights flash
Old Sep 25, 2011 | 09:43 PM
Colton_04's Avatar
4x4 hi and lo dash lights flash when truck is in park. Does anyone have an idea why.
Old Sep 25, 2011 | 11:53 PM
SSCULLY's Avatar
New or Old body style 2004 ?
Old Sep 26, 2011 | 01:39 AM
Colton_04's Avatar
New
Old Sep 26, 2011 | 01:40 AM
Colton_04's Avatar
Not only when in park that's when I first realized it but its just at random times.
Old Sep 26, 2011 | 11:15 AM
SSCULLY's Avatar
I would take a SWAG that the transfer case to PCM circuit is having an issue, or the plates in the transfer case are causing the flashing condition.
Huge SWAG that the PCM to instrument cluster is having an issue, but I would expect other symptoms ( something akin to crank no starts, false theft indicators, etc ).
Start by checking the fuses for the 4WD system with a meter on both pins, when installed.
F11, F29, F30 and F111. These are hot all the time, and regardless of the key position, you should have + VDC on both pins when installed.
The other side of these are at the PCM, Connector C175B, pins 12 & 13
Check the connector on the transfer case for corrosion or dirt / oil clean if necessary.
These are the starting points that I see looking at Cell 34 for the 4WD system
Old Sep 26, 2011 | 12:23 PM
Colton_04's Avatar
thanks ill see if i can figure out what this means
Old Sep 27, 2011 | 03:21 PM
Colton_04's Avatar
it was just a simple 4x4 fuse thanks for your help
