Wires all over please help!
Old Sep 6, 2011 | 04:51 PM
stickeegreens's Avatar
The previous owner of my f150 has someone install an aftermarket power window kit on both sides. They had crappy solder on them and had come off. Yesterday i resoldered both wires on the driver side. But when iw ent to put the plastic part back onto the metal door i accidentally dropped it cause the wires from the back of the window buttons to come of. Now i have 14-16 wires all colored coded just lying array. I tried connecting like colors and this did not work. Has anyone installed a window kit themselves who could point me in the direction of a manual. or at lleast tell me which wire is the power so i can try to put my left window up. Thanks!
Old Sep 6, 2011 | 06:38 PM
MossyOak3006's Avatar
Have you checked your fuses that are hooked to the window system? It's very possible that some wires touched when they got all mixed up and blew a fuse. That's the easiest thing to try first if you haven't yet
Old Sep 7, 2011 | 01:58 AM
code58's Avatar
If the system has a name on it, you can possibly go to that comapnies site and download a diagram. If not, e-mail them with the explanation and they will probably e-mail you a diagram.
Old Sep 7, 2011 | 05:14 PM
thank you code 58, looks like i'll be taking the door panel off tonight...And MossyOak3006 the fuses were the first place i went, i figured since i had the door panel off at one point in time it had to be behind it, sure enough....
Old Sep 9, 2011 | 05:37 PM
Steve83's Avatar
It would REALLY help to know what YEAR the truck is... Put it in your profile &/or signature.
