1998 motor swap with 1999 4.6
Swapped motor out of a 1999 f150 4.6 v8 into a 1998 and charging system does not charge the battery. Can see the volt meter going down on instrument cluster. Any help?
Charging system does not charge battery, as in no output from alternator ?
Did you check the alternator field fuse & harness ?
Thread on the topic.
https://www.f150online.com/forums/el...nator-why.html
