Could I get noise?
Old Aug 26, 2011 | 03:59 PM
borrego97's Avatar
Could I get noise?
I want to connect my piaa lamps in a way that I can turn them ON when the ignition is in accessory (like the stereo) so if a connect the lamp switch to the same wire as the stereo, could I get some noise in the audio?
(it is an aftermarket HU, and the now I just need to power the lamp switch to be able to turn them on)
Thanks!
Old Aug 26, 2011 | 04:05 PM
SSCULLY's Avatar
Should not, the switch is power the relay coil, there should be nothing that causes harmonic distortion.
Old Aug 26, 2011 | 04:25 PM
borrego97's Avatar
Thanks SSCULLY! that was my only doubt, I only need to connect that wire I'll be happy until I see another modification on this site hahahaha
