How to install Check Engine Light
Old Aug 20, 2011 | 12:09 PM
kbldawg's Avatar
I have a 5.0 HO EEC4 injected 78 F150.
I'd like to have a working check engine light and I'd like to use the "fasten seatbelt" dummy light on the dash as my check engine light.
Does anybody know which wires I need to connect the dummy light to?
Old Aug 20, 2011 | 12:28 PM
Steve83's Avatar
Does your new harness have a connector like this?
Read that caption: the CEL goes from key-switched power (Wh/Pu or R/Y or Pu/Y or...) to Pk/LG.
Old Aug 20, 2011 | 02:32 PM
kbldawg's Avatar
Thanks Steve, yes I do have those under the steering column. I've been using them to read codes using a 12v test light.
So the power to my CEL just has to be a key on source and the other I could splice on to the CEL wire on the diagnostic port? Sounds easy enough. Now I gotta find the fasten seatbelt wires. ;-)
Old Aug 20, 2011 | 06:30 PM
Steve83's Avatar
Why not just add a 12V light somewhere? If you get an illuminated switch & install it in the dash, you can wire it up so the switch triggers the diagnostic mode, and its illumination is the CEL all the time.
