1997 f250 ld #5 what components other than the a/c is in that circuit?
so i shorted out the a/c switch and now it keeps poping the #5 fuse. i'm thinking i have in some way weakened a relay or some other component in this circuit. so my electrical system question is, what other components work off of this circuit?? and where can i find a good wiring diagram for this truck that shows all the fuse/relay/wire color codes etc? i am having an electrical nightmare meltdown at this point. btw, have you ever simpily traced the wires on this truck? i went to the pick a part the other day and removed the dash on a 99 f150 simpily tracing the wires with out a wiring gude is an understatement, and simpily removing the dash
what a trip that was
to the ones that have removed there dash
No relays for Junction Box Fuse #5.
This controls :
1. Auto Trans - DTR ( Digital Transmission Range ) Sensor or Manual Trans - Backup lamp switch.
2. DRL module if equip'd with DRLs
3. Speed Control Servo
4. Function Selector Switch ( for HVAC )
5. Blend Door Actuator.
Which AC switch did you "short out", and what do you mean by "short out"
This controls :
This controls :
This controls :
so are you going to help or what? i have unpluged everything i can see to unplug, but still its blowing the fuse. its kinda difficult to work it out on my own. guess i will just move on, i dont get this fourm or the lack of help at all.
Excuse me ???
Bit demanding for free help now, aren't we ?
Ignore list for you
Ignore list for you
after a few days looking and searching, it looks like it was the bottom dash panel screw. it was somehow shorting it out. as soon as i put the one screw in under the steering wheel, it poped the fuse. not sure why its grounding out there.
