2000 F150 keyless entry module there is picures
Old Aug 11, 2011 | 09:23 AM
Blue Devil's Avatar
Hi everybody
Can someone tell me where the keyless entry module would be located on my 2000 F150 XLT ?
my truck equipped with factory anti theft system and power door lock.
because I've tried to enter into programming mode but the doors aren't cycling
I follow the programming by cycling the key from off to on 8 times but nothing happen.
I would like to install a factory keyless entry if I could find the module
I hear that the module is below steering wheels is it the white box in the pictures
Old Aug 11, 2011 | 12:09 PM
SSCULLY's Avatar
The Anti Theft as in PATS key or as in a dealer installed Ford Gold VSS ?
The RKE module is mounted behind the dash, towards the parking brake mech on the kick panel.
Quick search in this forum produces 192 threads on the topic, here is one of them :
https://www.f150online.com/forums/el...ry-module.html
If you do not have the RAP module installed, and still want RKE, get an aftermarket one. You will have less work and cost even going with the Ford Silver remote start / RKE.
