scanner prob.
Old May 2, 2011 | 09:20 PM
briansadlon's Avatar
scanner prob.
04 f150 4.6ltr i cant get into the system with a scanner tried 2 diff. ones. It says unable to communicate with vehicle any ideas what would cause this?
Old May 3, 2011 | 07:08 AM
SSCULLY's Avatar
Usually a blown fuse for the OBD-II port, which is the same as the Cigar lighter.
Old May 3, 2011 | 09:14 PM
well what if both lighters work? then it cant be the fuse?
Old May 3, 2011 | 09:35 PM
projectSHO89's Avatar
Check to see if your scanner is CAN-capable. The 2004 trucks switched from the old communications protocol to CAN making older scanners obsolete.
Old May 4, 2011 | 12:42 AM
SSCULLY's Avatar
Both lighters ?? There is 1 Cigar lighter and 1 power point, and they are on 2 different fuses.
projectSHO89 makes a good point.
