No power to fuel pump
Old Mar 9, 2011 | 04:19 PM
1fast4.6's Avatar
Originally Posted by SSCULLY
You mean you have pressure. Unless you checked it with a gauge, it is a guess.
BTW: What started all this ( ground, fuel inertia switch, etc ).
Just curious how all this stuff happened.
I took the truck completely apart :P and just now after 3 years im trying to get it to come back to life!
Check the link on my sig about installing air suspension
Old Mar 9, 2011 | 04:41 PM
SSCULLY's Avatar
OK, that helps a bit. Did you check that the connectors for the Cam Position Sensors are installed ?
FIY : I have sigs turned off, got sick of the huge graphic of oneupmansship
Old Mar 9, 2011 | 04:59 PM
1fast4.6's Avatar
Ill double check
Old Mar 9, 2011 | 05:13 PM
1fast4.6's Avatar
Sensor is plugged in
Old Mar 9, 2011 | 09:07 PM
1fast4.6's Avatar
Checked all my grounds and all checked out good. Both sensors are connected. Is the coil packs grounded through the PCM? They seem to have juice all the time when the key is on. If so it has me scratching my head as to why its not working. The two fuses in the box are good aswell.
Old May 24, 2015 | 02:01 PM
65fordsbabygirl's Avatar
I tried what sscully said jumped a wire in the distribution box that went to fuel pump relay pump came on then put the relay back it still runs don't know what the fix was guess the old girl just needed a shock !!!
Old Sep 5, 2016 | 12:17 PM
Bruce Owens's Avatar
Ok I have the same problem really..
I jumped my fuel pump relay but still isn't coming on.. I ran a hot wire and the pump came on but now power to the pump from harness.. It does have power in the relay and in the fuse... And fuel pump is good.. Check engine light is on but when I scan it it does not show any codes... Had same problem with other scanners I tried... And PCM fuse and relay are good???
Old Sep 5, 2016 | 11:39 PM
SSCULLY's Avatar
Can you complete your profile or post the information on your truck ?
