battery indicator light, gauges out
Old Feb 3, 2011 | 10:41 AM
yukhntr's Avatar
Just encountered an issue and not sure of cause... panel battery indicator light came on but kept going on/off as I'd drive. However later (in the dark unfortunately) I noticed radio would go off if headlights were switched on, plus all my gauges went to nothing...
Is this a fuse or harness issue, alternator issue, or battery? My panel lights, lights, blinker, etc. were all barely working when I made it home... Any suggestions of where I can look to fix? 1999 F150 XLT
Thanks!
Old Feb 3, 2011 | 10:46 AM
Get the battery checked. This is often a sign it is failing.
Old Feb 3, 2011 | 11:01 AM
you can't properly test an alternator unless you have a good battery, so you're gonna need to start with a battery first and go from there
Old Feb 3, 2011 | 11:34 AM
Steve83's Avatar
Before testing or replacing the battery, remove, inspect, clean, & tighten its terminals, and FULLY charge it. Read these captions:
Before testing or replacing the alternator, read this caption:
To get both tested thoroughly & accurately, find a shop or dealership with a MidTronics tester (all dealerships of all brands are required to have one for battery warranties) similar to this:
Old Feb 3, 2011 | 11:46 AM
yukhntr's Avatar
Ok, thanks. I will try that step first.
