'02 fog light mod
Old Jan 16, 2011 | 09:48 PM
ctsailor55's Avatar
'02 fog light mod
I have an '02 F150XL and I've been reading the threads about modding the light switch so the fog lights will work when the switch is in parking lot mode. I modified the switch per instructions so the arm will work. The issue comes down to the wiring. There are many threads but which one is accurate for a 2002? What wires get jumped, cut, and what fuses?
When I first did the modded install, I had fogs only with head lights and fog light indicator (as OEM). I re-installed it... nothing. No fogs, no switch lights, nada! Your thoughts?
Old Jan 17, 2011 | 09:48 PM
ctsailor55's Avatar
Bump
Can anybody tell me which thread is the accurate mod for an '02?
Old Jan 17, 2011 | 10:32 PM
SSCULLY's Avatar
Think the ramp modification how to in the technical articles section here.
This is the diagram
If you did the ramp work and the switch is dead, either the connector is not in all the way, or you went a bit too far on the switch ramp mod.
Old Jan 25, 2011 | 11:09 PM
ctsailor55's Avatar
Thanks Scully. If I have this right, I did the ramp mod so now I just need to jumper the brown wire to the white with black stripe and remove the #27 fuse? Thanks for the help.
Old Jan 26, 2011 | 07:13 AM
SSCULLY's Avatar
That is correct
