Adding Fog Lights in Bumper
Old Dec 22, 2010 | 08:12 PM
bcbnine's Avatar
Has anyone added fog lights in the opening of the front bumper? If so, please post pics and maybe some instructions. I would like to add some yellow fog lights in the opening of the front bumper on both sides of the lisence plate bracket. I want to run a toggle switch to the dash so I can use them for rain/fog days. I have a 2007 SuperCrew with the factory fog lights.
Thanks,
Blake
Old Dec 22, 2010 | 09:29 PM
DJ2007's Avatar
I mounted some driving lights in that opening. Check out the pics in my profile.
Old Dec 22, 2010 | 09:44 PM
bcbnine's Avatar
That is what I am looking to do. Thanks for the response. I sent you a PM!!
Old Dec 23, 2010 | 01:54 AM
Steve83's Avatar
Tap into the fuel pump relay output & pull that wire to the toggle in the dash. Run the wire out of the toggle to pin 85 of a Bosch/ISO relay. Run pin 86 to the high beam indicator circuit. Add a fuse in an empty location in your fuse block & run that to pin 30 of the relay. Run pin 87 to the fog lights. That'll make them safe, fully automatic, & legal.
