seat belt chime with belt on
Old Dec 12, 2010 | 01:33 PM
JJDH's Avatar
on my 2002 ford explorer, the wifes car, the seat belt dinger dings even when the belt is latched. It is intermittent. Any ideas.
Old Dec 12, 2010 | 04:03 PM
SSCULLY's Avatar
Are you sure it is the seat belt warning chime ( should also have the seat belt indicator on the cluster ) ?
When you turn the key from off to run ( do not start ), does the airbag indicator illuminate ?
Old Dec 12, 2010 | 07:15 PM
JJDH's Avatar
The yellow airbag indicator does illuminate. it has the red seatbelt indicator as well. i have had the dinger disabled since i bought it with the procedure in the owners manual
Old Dec 12, 2010 | 07:31 PM
SSCULLY's Avatar
The warning chime is disabled and it is going off with the seat belt attached ?
You have never changed the battery since 2002 ?
Old Dec 12, 2010 | 10:59 PM
JJDH's Avatar
I purchased the vehicle in 2004 and have changed the battery. I dont recall ever needing to re do the disable method though.
