front right signal light intermitent??
Old Dec 10, 2010 | 04:45 PM
lindenj's Avatar
Hi guys,
My front right signal light will take a sleep every once in awhile and not work. Then it decides to work....it is an intermitent prob......has anybody had this issue and have any remedies...i changed all the bulbs
thnx
Old Dec 11, 2010 | 02:59 AM
code58's Avatar
1st thing I would do (especially on a '92!) is pull the bulb out, take a drill (rechargeable if you have one) and put in a 1/4 in. bit and then take a wad of fine steel wool about the size of a large marble and let the bit wrap it around the end and then use it down in the socket to clean the contacts and walls up. Don't let the bit wear through and chew the socket up. Works like a charm, and if that doesn't do it, you'll have to look elsewhere.
Old Dec 11, 2010 | 10:24 AM
Steve83's Avatar
Read this diagram & follow the links in its caption:
Old Dec 11, 2010 | 10:28 AM
lindenj's Avatar
Great idea!!!...Thanks a bunch!!!
