need help asap!!
Old Dec 5, 2010 | 08:50 PM
danielandbrenna's Avatar
need help asap!!
i got this truck last week its a 97 f150 stepside 4x4 4.6 triton automatic. i drove it for 2 or 3 days and was going down the road the other day in it and smelt somthing get hot and all at once it quit pulling and the truck just died so i had it towed to the house we got to looking and someone replaced the #24 30 amp fuse in the power distrabution box with a 80 amp fuse there for whatever happened it blew the 80 amp fuse and burnt the relay up so we changed fuses back to 30 and replaced relay now truck will start but then blows the same fuse again then all it will do is crank till u change the fuse then itll just blow it again but it dosnt do it in a pattern just when it wants to then today it got to were it would blow the fuse automsaticly when u tried to start it need help could it be a grounded wire or what ???
Old Dec 6, 2010 | 08:18 AM
SSCULLY's Avatar
Which fuse #24 ?
BTW: Do not cross post threads in multiple forums.
Old Dec 6, 2010 | 07:59 PM
under the hood the maxie 30 amp fuse #24 it burnt relay 6 up and i changed it
