90 f150 ignition issues
Old Oct 31, 2010 | 10:36 PM
Matt N's Avatar
Hi everyone, got a problem dealing with a 90 f150 2wd auto transmission non tilt wheel.what happened was you would turn the ign key & truck wouldnt start just nothing a couple days prior key was hard to turn so i changed the lock cylinder no lock same thing,changed the ign switch same thing now when i manually move the rod & push it into the switch more truck starts fine i have adjusted the switch everyway i can & nothing.everything else works when in the run position fuel pump hums lights come on dash just wont start & also the gear selector wont go any further than reverse! any ideas?
thanks in advance
Matt
Old Nov 1, 2010 | 01:46 AM
Steve83's Avatar
Does it have cruise buttons on the horn pad?
Old Nov 1, 2010 | 11:08 AM
Matt N's Avatar
cruise buttons
yes the buttons are on the wheel
Matt N's Avatar
the horn pad i meant
Old Nov 2, 2010 | 09:40 AM
Steve83's Avatar
Then it's a tilt column. Gently rock the wheel up & down while pushing the blinker stalk forward.
The actuators are broken, and they're PITAs to change. Call around to the locksmiths & used car lots for a steering column specialist who'll do the job for ~$100. Or call the junkyards for a whole used column for ~$80, but it might go out soon. Either one will be less hassle than changing the actuators yourself.
Old Nov 8, 2010 | 10:31 AM
Matt N's Avatar
your absoulty right it was a PITA! I attemted to put the new acutator in for 2 days & finally i went to the junkyard & got a whole new column took about 40 min to put the new one in! wish i would've done that in the first place!
