Adding missing wires for factory fog lights?
Old Oct 28, 2010 | 09:39 PM
Blue2005F150's Avatar
So according to the diagram in my Haynes manyal i have the wiring for the fog lights except for the tan/org coming from the cjb to the lights. Can i just add that wiring from the cjb? Both the relay and fuse is there. I have the houseings alredy installed purchased pig tails to plug into the bulbs. Thanks in advance.
Edit: I also dont know what plug or pin the tan/org wire is supposed to exit the cjb.
Old Nov 8, 2010 | 07:42 PM
no one has done this?
Old Nov 8, 2010 | 08:20 PM
150 flareside's Avatar
Please use the search feature, it really does wonders. I have done this and the results are in the search. Try "adding factory fogs".
Old Nov 9, 2010 | 10:53 AM
HutsonHawk's Avatar
--> Here<-- Man
Old Nov 9, 2010 | 12:41 PM
SSCULLY's Avatar
Linking a completed search does not produce the same results you got.
Once you get done with it, that search ID is invalid
Clear your cookies, and click on it to see what happens ( give you a hint, "Sorry - no matches. Please try some different terms." )
