No Power to ECU
Old Sep 12, 2010 | 04:34 PM
Brad Ackman's Avatar
No Power to ECU
I was driving and the truck just stopped and lost all power, now I have no ECU power my code scanner says error at the connection. Does anyone have any suggestions on what to do.....
Old Sep 12, 2010 | 05:37 PM
projectSHO89's Avatar
Start by identifying your vehicle to include year, model, engine, and transmission.
Have you checked fuses that are listed in owner's manual? No owner's manual and 96 or newer? See below.
Old Sep 15, 2010 | 07:35 PM
ELVATO's Avatar
My 03 Expy did that a bit ago. It was a faulty PCM board.
In your case, it may just be the PCM relay that died. Try switching it out.
Also, info on your truck would be helpful.
Old Sep 15, 2010 | 10:01 PM
papajohn's Avatar
start by checkin all the basics which includes batt voltage, batt connections, and fuses. and CHECK FUSES WITH A TEST LIGHT. just because a fuse 'looks' good does not mean it is not bad.
