ford f150 reg cab
ford f150 reg cab
2002 f150 reg cab power windows don't work, ran power to both motors and and they work properly, replaced the master switch (drivers side) still no power to the motors, can't seem to find a fuse in the p/w system does that make sense ??????? help somebody its hot in phoenix az
The owners manual lists the fuse that you need to check as ACC delay relay.
The other thing to check after the fuse is the ACC delay relay and for a broken wire in the a-pillar to door harness.
