Lighted Running Boards
Old Jun 26, 2001 | 03:03 PM
chmiel's Avatar
Post Lighted Running Boards
I got a set of Westin Lighted Running Boards for my 2000 F150/XLT/7700. I was intrested to find anyone who has already done it to see if they have any suggestions on the wiring, even a good place to get the wire through the firewall on my truck. to a good place to tap the courtesy lights relay outside the cabin.
Thanks,
Old Jun 26, 2001 | 04:43 PM
Firezap's Avatar
Cool
I installed these lights under the body to come on with the dome light. Under the passenger side doorsill is a bundle of wires. I can't remember the color but there is a hot and a door switched in that bundle. As for where to run the wires there is a grommit in both doorsills, I ran the wire behind the rear seat under the carpet for the drivers side.
Hope this helps.
<A HREF="http://www.firezap.url4life.com" TARGET=_blank> </A>
GOLD RUSH
'99 F150 XLT SC SB 4x2 Harvest Gold
Factory
5.4 - 3.55 limited slip - Trailer towing package - In-dash CD player
Aftermarket
Ford Beanie bear - Slip on extender mirrors - Powerstop brake controller - Covermaster C1000 topper with wing - BugflectorII Ventvisors (front&rear) - Ford Lumi Logo (Front & Rear)- Steelhorse Billet grill - Ford hitch cover - Yellow wire loom - Hyper White head light bulb - Painted to match AVS slotted taillight covers - Ford system 4 alarm - Clear turn signals - "Blazer" strip reflectors under tailgate - FORD script antenna painted to match - Cup holder courtesy lights - IonOptics driving lights as reverse lights - 12 Volt power outlet in bed - Power port/Cigarette lighter courtesy light - K&N filter W/ Airbox removed) - Matching steering wheel cover - Painted engine compartment -Airhorn (Compressor and 1 gallon tank) - 1 set 6" 150 watt sealed beam offroad lights (Black) - 1 set 5" 100 watt offroad lights (Black) - 1 set Rally 35 watt driving lights (used as DRL) - 55 watt curb side courtesy lights
On Order
1 set oval fog lights - White face gauge kit - Door sill protector (4 color matched)
Next who knows???
<A HREF="http://njf150truckclub.homestead.com" TARGET=_blank> </A>
firezapper@f150world.net
[This message has been edited by Firezap (edited 06-26-2001).]
Old Jun 29, 2001 | 09:14 AM
chmiel's Avatar
Post
When you placed the lights under did you tap off of that line directly or did you go through a relay?
Old Jun 29, 2001 | 11:45 AM
Firezap's Avatar
Cool
I just went directly. You could use a relay there is plenty of room under the sill
