Question about plug behind panel in 2wd--->
Old Jun 22, 2001 | 08:35 PM
jewellboy's Avatar
Question Question about plug behind panel in 2wd--->
I have a 2wd '01 SuperCrew, and I have a question about the plug that seems to be the one that would be used for the 4wd switch. I had the trim panel off around the radio and I noticed it sorta blanked off at the back of the panel. I am going to be installing a mobile phone kit soon, and I would like to (if possible) use these wires for 12V consant, 12V switched and ground. Any ideas what the ****ion/polarity/votage of these wires might be? Thanks for any input.
Old Jun 22, 2001 | 10:43 PM
hmustang's Avatar
Post
If you have a volt meter you can find out what wires are what and go from there if not go and buy one as it will come in handy for checking wires fuses for when ever you do electrical work on your truck or home.
Old Jun 23, 2001 | 07:35 AM
JA_Stang86's Avatar
Cool
If you do check with a voltmeter and you find no power, look to see if you have any fuses in the 4x4 spaces in the fusebox. They are not normally installed if the truck is not equipped. Not sure where the switch is supplied from.
Jeff
1999 F-150 Lariat 4X2
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield
Stull billet grill
VentVisors
Class III hitch
Ford molded mud guards
Soft tonneau cover
Factory CD with changer
Tinted windows
Factory fog light kit
http://www.my-f150.com/lariatregcab/
Watch out NHL, Jagr and super Mario
Best in the buisness
