Just installed Super Whites (80/100), have a question.
Old Jun 2, 2001 | 09:35 PM
Newbie46's Avatar
Question Just installed Super Whites (80/100), have a question.
so far, no problems. But I've heard that it might fry might stock harness. is the factory harness really that weak? Some have replaced theirs with heavier duty one. Please, help if you've done this before.
2000 EXPEDITION 4.6 3.31 Rear, Poweraid Spacer, UltraFlow muffler, 6.8 inch TV with tuner/VCP, Full alarm and Auto-Start.
New Addition:
2001 F150 SUPERCAB 5.4L 3.55 LS, Airaid FIPK, Full alarm and auto-start, 50 series 3 chamber 3inch in/out Deltaflow Flowmaster
Swept Side style, Beltech 2 inch rear shackles, SUPERCHIP, billet grille, Lariat wheels and tires (275/60/17), Billet antenna by TRENDZ, Daytime running lights(if I can get it to work), Lightning 180 degree thermostat, White face gauge insert with EL lighting, Custom stereo system currently in the works.
COMING SOON:
pulleys, remove cats, 2 inch drop all around.
Old Jun 5, 2001 | 11:35 PM
Newbie46's Avatar
Post
up
Old Jun 7, 2001 | 02:16 AM
Newbie46's Avatar
Post
nevermind, I asked the dealer and they said it should work fine. These newer trucks (I'm assuming 2000+) can handle more load than previous (they say) so I'll keep the bulbs and inspect the harness regularly.
New Addition:
COMING SOON:
Old Jun 21, 2001 | 10:11 PM
Boss96Hog's Avatar
Post
NEW,
I installed a new harness made by Painless Wiring that draws power directly from the battery. The system uses the factory harness as the triggers for the new 40amp relays, one for low beam, one for high beam. This allows your headlights to work exactly the same from your factory switch.
The difference in brightness is AMAZING to say the least. With the factory harness, the light was blue and kinda dull. With the new harness, they are truely bright white.
This is one mod that was very worth while. I got the kit from Summit, but there was one glitch with it. The kit was set up for 9004 bulbs. Painless says this kit will work with both 9004 & 9007 bulbs. However, they neglected to realize that even though the 9004 and 9007 socket is the same, the wire positions are different. Once I figured out which terminals were which, all I did was pop the connectors out of the waterproof harness and switch their locations to match the 9007.
Boss™
Ordered June 29th, 2000; took delivery Nov. 28th: 2001 F-150 Lariat, Oxford White/Silver Supercab 4x4, Styleside, 5.4L, 7700# payload, Class III Tow, 3.73LS, Skids, Leather Captains, 4W disc ABS, shift-on-fly, keyless.Engine build date: 10-25-00
Modifications:
"Protected by the Owner with his 2 friends, Smith & Wesson" sticker, Westin Chromed Stainless Nerf Bars, ARE LS II bed cover, Bedrug™, Gibson Swept Side Cat Back, K&N filter w/airbox mods, Hyper-White headlight & foglight bulbs, Pioneer DEH-8200R, Ventshades(not on back doors), Hood deflector, Superchip.
Future Modifications:
3" body lift with at least 33's, alarm/pager/auto start system, stereo system
Old Jun 21, 2001 | 11:09 PM
Newbie46's Avatar
Post
well, there is one problem though, I finally installed my daytime running light so I can't use any aftermarket harness. I'll keep probing on this and will post what I find.
New Addition:
COMING SOON:
Old Jul 12, 2001 | 07:00 PM
JasonG's Avatar
Newbie where did you get your super white bulbs from and how much were they? I am hoping to get some in the future
Old Jul 12, 2001 | 09:41 PM
dogcam's Avatar
JasonG, go to the online store here on this forum. Roger sells them, have had them for almost 2 years and work great.
