Programming a remote
Old Jun 16, 2001 | 10:12 PM
Vette454's Avatar
Post Programming a remote
I need help i got a new factory remote for my F150 would like to program my truck for it , any of you guys out there ever done it? I know how to do a nissan one , wondering if fords any different.
Old Jun 18, 2001 | 01:25 PM
buschman's Avatar
Post
RTFM! It's pretty easy, but have all the remotes handy before you start the procedure:
Turn key from OFF to RUN (not Start!) 8 times quickly and then leave it in RUN. The locks will cycle indicating you are in 'Program Mode'. Press any button on the first remote, the locks will cycle to confirm it has been programmed. Do the same with the other remotes (up to four?). After you have programmed all the remotes, turn the ignition OFF and the locks will cycle once more.
You must re-program all your remotes at the same time as they are all erased when you enter 'Program Mode'. Good Luck.
Old Jul 5, 2001 | 10:53 PM
batman95630's Avatar
I have a 2000 XLT with the TRIAD system installed. I tried the above procedure and it never goes into program mode. It works fine on my Explorer. Anyone have any ideas??
