heated mirrors
Old May 29, 2001 | 10:04 PM
white rod 01's Avatar
Post heated mirrors
Has any one installed heated mirrors from an expedition on an F150? I would appreciate any info!
Old May 30, 2001 | 10:45 AM
Shark99's Avatar
Post
Yes....Muth replaced mine under warranty, and I opted for the upgrade to the heated mirrors. Very easy install. Although you have to buy a switch to control the mirrors (from a 93' explorer). And having the heated mirrors is well worth it. There are no instructions...but if you do a search on ford-diesel, there are a couple of good posts that explain it in detail! (search for a member named Beagle1)
2000 XLT Silver 5.4L SC 4X4 ORP 157"wb Ford Floormats, MudFlaps, Cabin Air Filter, lighted emblems, lighted interior door handles(all 4) Chrome Grill (4x2 style), Diamondplate bed caps, Pro-Tech tool box, Air Box mod, Muth Heated Signal Mirrors, Custom Gauge Pod-(water temp, trans temp)
Perma-cool 8" Electric Trans Cooler Fan, 2.02" Radiator, 16" Derale cooling fan, Superchip (flipchip), Map lights in overhead, tinted windows, back up lights, soundproofed cab.
Old May 30, 2001 | 08:10 PM
Post
Shark99, thank you for the info on the mirrors. Were your mirrors Muth or stock ford? I really would like to get ford parts.93 explorer switch sounds good tho! Again thanks!
Old May 31, 2001 | 10:58 AM
Shark99's Avatar
Post
White rod 01-
I did not have signal mirrors stock. Although all 00 and new trucks are wired for them (makes install easy) Muth is the OEM for the ford signal mirrors. IF you buy them from ford, there all the same...exept you paid too much, and muth has great customer service.
Old Jun 2, 2001 | 11:20 PM
GIJoeCam's Avatar
Post
Do you know if it's possible to upgrade to only the heated mirrors? I've got the 2000 mirrors with the turn signal on the housing, not behind the mirror. I'd definately like the heated mirrors, though...
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof($1000), built 11/99 picked up 10/00!Clear Corners($36), Manik Stainless Steel 1-piece brush guard($700), Custom CB wiring, Uniden PC76-XLW CB radio($100) with K-40 Magna-Mount antenna (for now [$40]), 1 set of 165 watt KC Daylighters (for now... more on the way... $140) Fog Light Switch mod(free!!!), Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbar w/ 2" stainless steel ball($80), Gray Tek Style Soft Tonneau Cover($250), Gray Line-X Bedliner ($450).
List of planned mods: Clear tails, torsion bar tweak, bug deflector, Chrome ORP rims.
93 Probe GT teal, OE rims painted to match, bone stock drivetrain, leaky exhaust.
Old Jun 3, 2001 | 01:10 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by GIJoeCam:
-Joe- Im in the same mode as u I would like to get the heated mirrors only for my 01 Lightning. Possibly from an Expedition or Navigator
</font>
