Wiring help for Pop&Lock remote tailgate latch
I've been trying all afternoon to get a Pop&Lock remote tailgate lock wired to my truck. Two things.
ONE - The instructions call for tapping into the wiring in the doorjam between the door and body. Lousy place. Can't fish a wire through the kick plate by the emergency brake with all the brackets and ***** crammed under there. yes, I've pulled off all the covers and things that I can. Is there a better place to make the connections?
TWO - The instructions say to splice into the pink/yellow stripe and pink/light green stripe wires. I did and tested the assembly before I installed. The power locks on the truck didn't work and the solenoid on the latch didn't either. I've tried their website (no technical info or phone #'s).
Any idea if I've tapped into the right wires and how to test the solenoid to see if it works? Thx.
2001 F150 Supercrew 4X2 (Gen III), Lariat, Arizona Beige Metallic, 5.4L, Towing Package, 3.55 LSD, Moonroof, Captains Chairs, Premium Sound, Extender
Ordered 12/14/2000, Received 2/9/2001 Life is Good...
Modifications:
Line X bedliner, Ford factory splashguards, Black Westin Step Bars, Aux Back Up Lights, Advance Cover folding hard cover, Extender Lock, Husky Floor mats, New Factory Ford transmission (replaced at 2100 miles)
Modifications:
StrongWind, When testing make sure you hit the unlock button on the drivers door or if your using the remote you need to hit it twice to unlock. I was able to tap into the correct wire under the door sill plate by the drivers seat pilar "B". The wires I used were pink/orange to unlock and pinkk/black to lock. Hope this helps.
<A HREF="http://www.fpage.com/rbaker/MN-Trap_SCrew_122300.html" TARGET=_blank>http://www.fpage.com/rbaker/MN-Trap_SCrew_122300.html
</A>
2001 F-150 SuperCrew 4X4 XLT – Silver w/Medium Graphite interior,
4.6 V8, 3.55 Limited Slip Axle, P265/70R17 OWL All-Terrain,
17” 10 Spoke Aluminum Wheels, Class III Trailer Towing Pkg.,
Remote Keyless Entry, Dual Media Ford AM/FM/CD Radio & 6 CD Changer,
Captain’s Chairs, Ford Cab Steps – Black, Engine Block Heater
Custom Dual Exhaust with X-Pipe, EGR Carbon Fiber Hood Shield ,Window Vent Shades ,Outland Grill Guard – Black ,PIAA 9051 Ion Crystal Fog/ Clear Driving Lights, Superchip, Airaid Intake System, A.R.E. LSII Hard Tonneau cover with remote lock, Python 1500 ESP Security System w/remote start, Clear Corner Lenses, Rhino Liner, TruckVault, Infinity Kappa 50.2cs in front door, Infinity Kappa 572.1cf in rear doors, Valentine One w/Laser Radar Detector & Concealed Display, 2000 Expedition Console, J&J Stainless Grille Insert, Lund Moon Visor, Pop-Lock in tailgate, 2001 Lighting Tails, Lighting Headlights, PIAA 1451 backup lights
[This message has been edited by MN-Trap (edited 05-06-2001).]
</A>
MN-Trap,
I was finally able to get to the remote tailgate lock this weekend. The wiring you reccommended was correct and much easier to install. Everything works great.
Thx again for the help!
