PLS HELP ME !!!
Old May 18, 2001 | 12:48 AM
GIORGIO's Avatar
Wink PLS HELP ME !!!
I NEED TO KNOW WICH WIRE I HAVE TO CUT TO STOP THE ELECTRONIC SPEED LIMITATOR
MY F150 LARIAT 5.4 TRITON IS IN ITALY (BROTHER) AND OVER THERE IS POSSIBLE RUN WITHOUT GET TICKETS
PLS LET ME KNOW
THANKS A LOT TO EVERYBODY
GIORGIO
Old May 24, 2001 | 07:59 PM
GIJoeCam's Avatar
Post
The only way I know of is by installing a superchip. However, I would not recommend this. Most vehicles that are top-speed limited are limited right near the top rated speed for the tires. If you exceed that speed, the tires could very easily give out (not something you want to happen at 120 MPH with a truck!) If you installed tires with a higher speed rating, then it would be safer, but not at all recommended due to the wear and tear on the other components in the drivetrain.
Sorry to get off-topic. I honestly don't know if there is a way to simply cut a wire and make that happen.
-Joe-
98 Explorer (Lemon Law Case in Progress)
'00 F-150, X-cab, 4x4, Lariat, Off-road, Trailer Tow, Holandia Sunroof($1000), built 11/99 picked up 10/00!Clear Corners($36), Manik Stainless Steel 1-piece brush guard($700), Custom CB wiring, Uniden PC76-XLW CB radio($100) with K-40 Magna-Mount antenna (for now [$40]), 1 set of 165 watt KC Daylighters (for now... more on the way... $140) Fog Light Switch mod(free!!!), Custom switch mounting plate and overhead console, Bully Stainless Steel Trailer hitch drawbar w/ 2" stainless steel ball($80), Gray Tek Style Soft Tonneau Cover($250), Gray Line-X Bedliner ($450).
List of planned mods: Clear tails, torsion bar tweak, bug deflector, Chrome ORP rims.
93 Probe GT teal, OE rims painted to match, bone stock drivetrain, leaky exhaust.
Old May 25, 2001 | 12:22 AM
starfi's Avatar
Post
Giorgio,
Do you really want your truck running faster than it is set to do???????? Keep in mind , it is not a Lamborghini.Besides I don't think you can get Ford engine parts over there.*** SMILES ***
