Dash change out
Old Apr 19, 2001 | 12:55 AM
Red'01 Sport's Avatar
Post Dash change out
Being new here im sure that this has been covered before but i can not find the related thred. I need to know what is involved in switching our a factory tach cluster for the standard one that came in my 01 truck. Any ideas on the cost of the new cluster and where is a good place to get one in Houston Texas??????? Thanks for the time
Red 01' Sport
JVC in dash
Cerwin Vega Upgrades
Spray in linner
Tinted windows
Old Apr 19, 2001 | 03:17 PM
Old Timer's Avatar
Post
Hi Red
Not sure if i understand you question?
Do you want to install an OEM gauge panel with the tach, because yours dosent have a tachometer?
If so, im trying to do the same & can tell you what ive found out.
OT
Old Apr 20, 2001 | 10:15 AM
Post
that is exactly what im trying to do.
my big concern is the cost of the replacement unit and where is a good place to get one. please keep me updated. e-mail me if it is easier.
thank you
<font face="Verdana, Arial" size="2">Originally posted by Old Timer:
Hi Red
OT
</font>
Old Apr 20, 2001 | 04:54 PM
Old Timer's Avatar
Post
Hi Red
Ck. posts under "Engine" 3-31-01 Pg.10
Look around that time frame for maybe more info.
Didnt mention what yr.truck you got. So this may not apply?? You may already know this stuff?
This for my 99SC XL 4.6L. EDIS/coil packs.
The only place i found for a OEM gauge panel with tach (speedo,oil,water temp.etc) was at my local Ford parts.
The cost was around 400.00 You simply take out the old panel & install new panel using existing wires.
Now, this is where its complicated. Dealer didnt have a complete wiring diag. for my truck. So no way of knowing if the wire from "PCM" is there that goes to the factory tach. Have to pull the panel out and look for the tach. wire. Haynes manual i have has partial wiring diag. shows tach wire from PCM & color.but???
My parts guy couldnt get any info. from his supplier with regards to: 99XL didnt come with tach only XLT, so how do we hook up tach. if wiring not there? Reply: Dont know!
So theres the rub. Someone gotta pull gauge panel out, ck. for tach. wire, if not there, then gotta go into the "PCM" for rpm pickup.
I can pull panel, but??
So i said man, this is a bummer, thats before i found "Test mode" in my diagital odometer. I can use it for tach. rpms, & other test. Works great, just small numbers & eyes blink alot.
All i wanted to do was install aftermarket tach. awhole lot cheaper, etc. but because of ign. change in 99, autometer did not have a tach. that would work on this new ign. At least thats what they told me at the time?
Isspro.com has a tach.(add on) that will work on this ign. system for around 200.00. Requires an inductive pickup sender that you have to mount to face of crankpulley cover. So thats a cheaper alternative.
There # 1-800-888-8065
So anynow, i kinda backed off temporarily, since this "test mode" is helping out, Autometer said check back, but last call still nothing, they dont have technology as yet. Funny, ISSPRO does. I just wanted a 40.00 addon, not 400.00 HA
Thats it, good luck OT
Old Apr 21, 2001 | 11:44 PM
Ian N's Avatar
Post
HI OT
I think the reason Isspro has a tach solution and Autometer doesn't is that Isspro specializes in instrumentation for heavy industrial equipment and autometer in performance automotive. The tach you are looking at was developed for diesel applications.
I'm surprised you couldn't find an old panel at a wrecker to try for under a hundred bucks.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
Old Apr 21, 2001 | 11:51 PM
KYFordFreak's Avatar
Post
I'm not saying all Ford trucks do but my dad's 94 F150 XL did have a tach wire already ran to inside of cab in the factory wire harness, it was just a matter of tracking it down. I would assume Ford would use just about the same wiring harness on every truck to keep costs down. But that's just my opinion, I could be wrong.
97 Ford F150 XLT 4wd 4.6L auto, Std cab/Long bed 2 tone royal blue w tan bottom, PW,PL, and PM, captian chairs w/arm rests
Current Mods
K&N Filter
Xact Plug Wires- 8mm
Ventshade side window deflectors,read window deflector, bug guard, headlight and taillight blackouts
custom hand painted Ford emblems on door jamb guards and under hood on plastic intake cover
plastic mud guards
custom 4x4 off road graphics
Ford hitch cover and license plate frame
Custom carpet liner (protects factory carpet)
Slyvania Cool Blue Headlight and fog lamp bulbs
oh yeah, one custom dent and scratch from a deer the night before deer season
Old Apr 22, 2001 | 04:56 PM
Old Timer's Avatar
Post
Hi Should have said i got tip from IanN. on Isspro. Thanks again. Sorry about that.
I was aware of diesel, just didnt post it.
Apparently not worthwhile for autometer to persue. I'm guessing most buyers are getting the OEM tach. with there new trucks.
Where im at, no late models at wreckers.
Still lookin.
Ill just use the "odo. test mode" for tach. read out, its giving me what i need to know right now.
Good luck & tks. OT
