door ajar chimes
Old Jun 3, 2000 | 08:50 AM
Loyd meeks's Avatar
Question door ajar chimes
Can any one tell me how to disconnect the chime without pulling fuse?
Old Jun 3, 2000 | 11:39 PM
Dennis's Avatar
Post
If all you want to do is turn the chime off while the door is open, just trip the latch in the door. The switch is in the latch. Don't forget to pop the handle to untrip the latch before you shut the door.
If the problem is that the door ajar chime doesn't go off even with the door closed, take it back to the dealer to have the latch replaced or cleaned. You can clean it yourself. Members have had good results with liberal spraying of WD-40 into the latch mechanism.
[This message has been edited by Dennis (edited 06-03-2000).]
Old Apr 12, 2001 | 11:02 AM
Jimmar's Avatar
Post
Try this :
https://www.f150online.com/f150board...ML/000369.html
2001.5 SuperCrew XLT 4X4
Silver Clearcoat Metallic
Deep Wedgewood Blue (accent)
5.4L V8
Chrome Tubular Step Bars (Ford)
Captains Chairs
Power Moonroof
3.55 LS
6750 GVWR
Class III Towing Pkg
Mods:
Harley Davidson Exhaust
'01 Lightning Head/Tail Lamps
Pioneer DEH-9200r
Boston Acoustic Components & 5X7s
Box Liner (Ford)
Splashguards (Ford)
Bug Defector Doubles as Rock and Sand/Salt Deflector in these snowy Canadian winters
To Come:
17" Rims/Tires
K&N Air Filter
